China Hosing lens flood light suppliers
ipa520p
14 Ara 2018
150W 200W Flood Light Housing with Lens
Product Description:
2017 hot model super bright 150W 200W COB Led light source flood light with Aluminum housing
Feature:
● Die casting aluminum housing with Optical grade diffused lens.
● Aluminum die casting prevent lighting, corrosion resistance and will not discolor, will not crack.
● Fast heat dissipation, long service life , precision aluminum dis casting radiator.
● High voltage, low current, energy-saving, environment friendly.
● Performance stability, high IP rating of water-proof and dust-proof.
● Long durability, 50,000 hours life-span for LED.
● Stable and durable, easy to installment and maintenance.
● Advance design of double waterproof , improve the waterproof performance effectively.
● Professional optical lens design, luminous efficiency is increased by 50%.
Our advantage:
1. Concentrate on led light housing die casting field for over 10 years.
2. Quality control from raw material to finished product.(we have own material factory also).
3. More than 800 sets of flood light housing for you to choose.
4. Advanced equipment :10 sets of die-casting machine from 100 tons to 630 tons, so we can make flood light from 10W to 500W.
5. We have talented and experienced engineers.
6. Strict quality control system.
7. Flexible forms of cooperation. Accept OEM and ODM.
8. Exporting for worldwide, with satisfied clients more than 50 countries.
9. Competitive price, excellent service, integrated certificate system.
Applications:
Tunnel, workshop, large-scale warehouse, stadium, factory plants, engineering construction
● Quality control: 100% inspected before packaging and shipping.
● Process: high-pressure die casting.
● Secondary process: Deburring ,drilling ,threading, milling, turning, CNC machining.
● Surface finishing available: shot blasting, polishing, painting, powder coating, anodizing, electroplating,Chrome Plating(Matt/Bright) , Nickle plating, Zinc plating, mirror polishing, trivalent chromate passivation, e-coating, etc.
● Input Voltage: AC85-265V.
● Working lifetime:50000H.
● Warranty period: 2 year.
● Packaging: standard export carton with foam inside suitable for long-distant ocean shipment and tough handling.
● Delivery time:Within 15-20days after received deposit and artwork confirmed.
Matters Needing Attention:
1. The light’s waterproof grade is IP66, able to withstand rains, but it can’t work under water.
2. Cut off power supply before and in installation process. If the product is damaged due to mal-operation, it shall not be guaranteed. Please have it mounted by a professional.
3. The light’s operating ambient temperature is between -20°C and 50°C. The temperature of operational site shall not exceed 50°C, to ensure the light’s service life.
4. Since the light power is high, when power line is arranged, it’s necessary to select a proper power line according to actual power, and supply power in single phase.
5. Please don’t dismount the light without authorization. Please contact professional maintenance personnel or the manufacturer if the light isn’t lit or is faulty otherwise.
If you have any preference for the 2017 hot model super bright 150w 200w cob led light source flood light with aluminum housing, please be free to buy the high quality light in stock from our factory. Leelo Lighiting is one of the leading flood light manufacturers and suppliers in China. You can rest assured to buy.China Hosing lens flood light suppliers
website:http://www.leelolighting.com/led-flood-light-housing/led-flood-light-housing-with-lens/
